Date/Time: Thu, 02 May 2024 15:57:55 +0000
Market depth historical graph
View Count: 563
[2020-03-12 14:30:11] |
User188188 - Posts: 7 |
Hei! Why I cannot see "Market depth historical graph correctly?" Can it be because of new Denali data? http://www.sierrachart.com/image.php?Image=1584023280151.png |
[2020-03-12 18:57:17] |
Go to that chart and select File >> Open Market Depth Window. How many levels of depth do you see? Second, attach a Chartbook with just that chart in it with the Market Depth Historical Graph set in the way that you want. You can follow these instructions to attach the Chartbook: Support Board Posting Information: Providing Chartbook with Only a Single Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-03-13 09:34:19] |
I see very many levels, perhaps 100 levels. But now, I see only one. Interesting. I attached chartbook. |
TEST_3.Cht - Attached On 2020-03-13 09:32:09 UTC - Size: 73.48 KB - 201 views Attachment Deleted. |
[2020-03-18 20:37:55] |
John - SC Support - Posts: 31309 |
We have looked at your chart and the Market Depth Historical Graph is displaying just fine for us. In general, it is very dark, as there tends to be one outlier which pushes the rest of the data into the lower percentages for coloring. We would recommend entering an appropriate value in the Maximum Quantity for Coloring Input. Refer to the information for that Input here: https://www.sierrachart.com/index.php?page=doc/StudiesReference.php&ID=375#StudyInputs_MaximumQuantityForColoring Additionally, we had to adjust the spacing in order to see the data for both the vertical and horizontal. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-03-18 20:39:19
