Date/Time: Wed, 15 May 2024 01:57:45 +0000
CQGWebAPI login
View Count: 519
[2020-03-12 13:17:36] |
User146810 - Posts: 1 |
When I try to log in to my account, I get a message that my username or password is incorrect. This only started recently and I didn't change anything on the login form.
[2020-03-12 18:13:53] |
Refer to: CQG Trading Platform Service: Common Error Messages While this is not the problem, you are also running an older version of Sierra Chart. You need to update to the current version: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
