Date/Time: Wed, 15 May 2024 15:57:05 +0000
bracket on signal
View Count: 546
[2020-03-12 12:07:58] |
markuz - Posts: 90 |
is it possible to code a trade based on color background based on alert condition (picture attached)
Tom_Signal_Bracket.png / V - Attached On 2020-03-12 12:07:37 UTC - Size: 224.47 KB - 205 views |
[2020-03-12 18:15:34] |
You just need to use the Trading System Based on Alert Condition study and use the same Alert conditions that you are using for the Color Background Based on Alert Condition study. Or write a formula which makes reference to the results of the Color Bar Based on Alert Condition study. Refer to the information here: Trading System Based on Alert Condition Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
