Date/Time: Thu, 16 May 2024 20:24:45 +0000
FRA40 Problem
View Count: 515
[2020-03-11 10:03:25] |
User68127 - Posts: 23 |
the FRA40 Daily (historical chart) gives false high or low values attached 2 graphs: FRA40 Daily: High 4825.4 Low 4666.5 Bad values FRA40 5 Min: High 4767 Low 4666.5 Good values Why these differences? Thank you http://www.sierrachart.com/image.php?Image=1583920420874.png http://www.sierrachart.com/image.php?Image=1583920480265.png |
[2020-03-12 09:28:01] |
We need some time to look this over and verify the session times and see if they are correct. Please just give us a few days.
[2020-03-13 03:52:59] |
In the case of the CFD symbols , the Session Times are explained here: Sierra Chart Real Time and Historical Forex and CFD Data Service: Historical Daily Data Session Times They do not follow European trading hours. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
