Date/Time: Sun, 04 Oct 2026 15:17:18 +0000
Lagging in the hole chart software
View Count: 730
[2020-03-11 06:51:53]
User967248 - Posts: 4
it is getting worse and worse. Got a three monitor system. Yesterday I tried to draw a simple Fibonacci in my 5 minutes Eurex DAX Future Chart, it was not possible. Because I was not sure if the problem is connected with the CQG Datafeed, I did disconect the feed: still it is such a lagging to work in the chart. What can I do? Is there a cache to make empty the software, used it over a year on daily basis, or ist there something to do for Maintenance the system?
Thank you in advance
thomas naumann /munich
[2020-03-11 07:36:54]
Refer to help topic 30:
High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often
There is no cache you need to clear or maintenance.
