Date/Time: Sun, 05 May 2024 01:30:21 +0000
Are CME options through Rithmic supported?
View Count: 1991
[2013-04-14 18:54:03] |
maxima120 - Posts: 144 |
Are they supported and how do I construct the symbols?
[2013-04-14 20:26:23] |
Whether Rithmic supports options or not, we do not know. You will have to contact your broker about this. The general Symbol format will be: [Option symbol]-[Exchange] Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-04-14 20:26:36
[2013-04-14 21:27:52] |
they do. question was whether SC supports them. Year ago you didn't support exchange spreads for example although Rithmic did. now you do. so I am just checking. |
[2013-04-14 21:39:34] |
You can use any symbol that Rithmic supports. We have supported exchange traded spreads for more than a year with Rithmic. And if there was a problem previously, it was just nothing more than a simple symbol parsing problem. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-04-14 21:45:17] |
sure. thank you.
