Date/Time: Sun, 04 Oct 2026 15:16:29 +0000
new GLOBEX daily bar not appearing at 1800 EST (denali)
View Count: 1061
| [2020-03-10 22:05:24] |
| cmb999 - Posts: 211 |
hi, I refresh historical daily chart at 6 pm EST, and cannot see new bar for the day
| [2020-03-11 00:26:01] |
You need to use this Edit menu command to cause that to happen: Edit Menu: Edit >> Download Data For All Historical Charts Also refer to: Historical Chart Prices: 12.6 - Always Beginning Historical Chart Bar at Specified Time According To Symbol Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-03-11 00:29:10
| [2020-03-11 12:10:28] |
hello, thing is, 1800 EST is the normal start time for the new daily bar. for the regular SC feed, i remember needing to manually refresh the chart to get the new bar to appear, which you all explained as something not easily fixed. however, it did appear after a manual refresh. with denali it seems not to show, even after refresh, until a set period of time later (30 min ? still trying to determine)
