Date/Time: Sun, 04 Oct 2026 15:17:26 +0000
Scale Range: Automatic to ignore studies?
View Count: 1997
| [2020-03-05 18:26:54] |
| User731023 - Posts: 167 |
Is there an option to choice and have the Scale Range:Automatic Ignore studies? Thanks |
| [2020-03-09 15:06:09] |
Is there an option to choice and have the Scale Range:Automatic Ignore studies? Thanks PS See attached in first request. |
| [2020-03-09 17:41:17] |
| Merlin - Posts: 83 |
You can set the scale individually for each study. For a study that you want scaling to ignore, go to "Study Settings". On the "Settings and Inputs" tab, click the Scale button and set the scale for that study to "Same as Region." This is all covered here: Chart Studies: Settings and Inputs tab |
| [2020-03-11 00:34:35] |
Refer to the information here: Chart Scale and Scale Adjusting: Basing Scale Only on Price Bars Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
