Date/Time: Sat, 18 May 2024 22:45:19 +0000
[Programming Help] - Line Break study - not working
View Count: 472
[2020-03-05 12:47:02] |
jimskin - Posts: 127 |
I noticed the Line Break study no longer works in SC v2050. I'm not sure if that's a standard or custom study.
[2020-03-13 10:17:04] |
Any support for this post?
[2020-03-13 10:46:29] |
Nothing has changed with this study and there are no problems with it. We tested it on ESH20. Check the Input settings for the study and set them appropriately according to the documentation.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-03-13 10:46:40
