Date/Time: Thu, 11 Jun 2026 19:13:43 +0000
cpp TPO profile
View Count: 1424
| [2014-01-08 17:30:41] |
| TradingMarketProfile - Posts: 120 |
Hello, I'm trying to draw the Single print automatically on the TPO chart as develloping but for this i need .cpp file so i'm not sure you are able to give it to me so can you do something yourself ? I hope i'm clear so just in case i show you picture that what i want.. http://www.sierrachart.com/image.php?l=1389202232210.png |
| [2014-01-08 18:26:31] |
No, the TPO Profile Chart study is not available as a CPP file.
| [2014-01-08 19:05:49] |
ok and can you do it ? or add an option ? |
