Date/Time: Mon, 06 May 2024 02:00:55 +0000
V964 small bug
View Count: 1972
[2013-04-14 16:55:26] |
N2S - Posts: 15 |
V964 "Chart"-"Show Menu" doesn't work |
[2013-04-14 17:31:27] |
This is disabled until further notice. Please avoid asking about this for now. We have run into way too many significant problems with all of these window modifications. It is not normal to be hiding and showing menus, scrollbars and title bars after a window is created. This creates various side effects.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-04-14 17:31:52
[2013-04-15 17:09:20] |
joshtrader - Posts: 439 |
FWIW, I am running 963 and have had no problems at all with showing and hiding menus. I created a keyboard shortcut, mapped it to a mouse button, and can show/hide the menu at will. It is great.
