Date/Time: Sun, 28 Apr 2024 05:07:51 +0000
spreadsheet trading system
View Count: 976
[2014-01-08 16:23:18] |
batman_ - Posts: 190 |
Does spreadsheet trading system supports simultaneous multiple products trading? say ES, 6E, CL each have spreadsheet trading systems executes order at the same time in one PC. |
[2014-01-08 18:00:10] |
Yes. This is supported. You will need a separate Spreadsheet System For Trading study for each chart for a symbol.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-01-08 18:00:36
