Date/Time: Thu, 16 May 2024 16:51:50 +0000
ahud dyagi8
View Count: 492
[2020-03-03 14:56:39] |
User495292 - Posts: 1 |
you people just unreal I trade at infinity brokers your chart is delay for weeks why??
[2020-03-03 17:38:58] |
This is a problem with the Transact data feed itself. The first thing we want you to do is to update Sierra Chart to the current version. Instructions: Software Download: Fast Update The newest version, uses a more compact message from the Transact data feed. Also refer to this thread: Feedback Requested Regarding Data Feeds and Order Routing Systems Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
