Date/Time: Fri, 26 Apr 2024 17:32:45 +0000
Creating bat files for Sierra Chart
View Count: 1471
[2014-01-08 15:10:34] |
vectorTrader - Posts: 86 |
Currently I understand that you can add a chartbook to the start up of Sierra chart and arrange the order of that chartbook. My goal is to have several chartbooks open, and then print the chart(s) in the attach windows of the respective chartbook. Is this possible? It would be very helpful for analysis at the end of the day and allow me to automate it since I don't have a secretary yet. hehe thanks If not can this be programmed outside of sierra? I am not a programmer so forgive me for niavety. |
[2014-01-08 17:59:03] |
There is no automatic way to Print charts. This needs to be manually done.
[2014-01-10 03:34:53] |
Lesmond - Posts: 21 |
This can be easily achieved using AutoHotkey scripts: http://www.autohotkey.com/ |
