Date/Time: Wed, 15 May 2024 08:03:57 +0000
Autoloop call function
View Count: 847
[2020-03-02 18:41:01] |
stephane1 - Posts: 110 |
I created a study that works well with historical data .... but in real time or in replay the intended alarms are not displayed. I think I am not well understood how the function is called in real time. If I understood correctly ... at each tick change the function is called? or at each bar? it depends if autoloop is on 0 or 1? In my study, I have a vector and variables which must not be initialized each time the function is called ... should we use persistent variables? but for the vector? thank you |
[2020-03-02 22:04:02] |
Refer to: Working with ACSIL Arrays and Understanding Looping: When the Study Function is Called You may want to use persistent variables. This is a programming level question and you have to make your own determinations. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
