Date/Time: Sun, 28 Apr 2024 20:26:24 +0000
help!
View Count: 976
[2014-01-08 13:09:38] |
dong7525 - Posts: 1 |
Socket closed. Windows error code 10053: 連線已被您主機上的軟體中止。 | 2014-01-08 21:08:58 TT Orders FIX Session: Socket connection was closed without any logout messages sent or received. | 2014-01-08 21:08:58 Disconnected from TT FIX Orders session. | 2014-01-08 21:08:58 Connection to the external service has been lost. | 2014-01-08 21:08:58 TT FIX: Disconnecting from Price Feed session. | 2014-01-08 21:08:58 TT Price Feed FIX Session: Sending a Logout message. | 2014-01-08 21:08:58 TT FIX: Disconnected. | 2014-01-08 21:08:58 Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-01-08 21:08:58 |
[2014-01-08 16:06:59] |
This is only part of the Message Log. We need to see the entire message log. Here are the instructions: https://www.sierrachart.com/index.php?l=PostingInformation.php#log Also, what particular TT broker are you using? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
