Date/Time: Sat, 27 Apr 2024 00:32:25 +0000
quoteboard not visible across different chartbooks v1070, and no net change data
View Count: 1236
[2014-01-08 12:59:43] |
4646ed - Posts: 230 |
Has this issue been resolved, or has it popped up again? I open one in one cb and go to another and it disappears; whether its detached or attached, same thing. Also, how long before net change and net change% show some figures? It's been an hour and they just show 0s. I'm using the fxcm sc data feed. Also: when using a forex feed when are the highs and lows set? 24 hours? Start of the NY session? Date Time Of Last Edit: 2014-01-08 13:03:21
[2014-01-08 17:17:53] |
A Quote Board is associated with a particular Chartbook. It will not be visible across different Chartbooks. So each Chartbook needs to have its own Quote Board. Net Change is not supported with the Sierra Chart Forex FXCM data feed. The Daily High and Low values are reset at 22:00 GMT time. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-01-08 17:18:11
[2014-01-09 07:19:26] |
Thanks for getting back to me. Any plans to make it visible across all chartbooks? It would be much more efficient and useful.
[2014-01-17 11:58:25] |
Futures Operator - Posts: 239 |
+1 on Quoteboard visible across all chartbooks, and that it's inefficient/messy to create and manage a duplicate Quoteboard window for each chartbook, across many chartbooks. FYI sairent, this was requested in 3Q last year and SC did say they would add it, but that it could take awhile. |
[2014-01-18 01:07:23] |
We will try to get to this soon.
