Date/Time: Sun, 04 Oct 2026 13:19:07 +0000
No live data-pls refer to messages below+ clearer query
View Count: 789
| [2020-03-02 15:52:23] |
| bootsy - Posts: 63 |
Hi there, Please see message below. I still have delayed data and haven't been able to trade today. Also, I have contacted my account exec and it turns out I clear through GH Financials which is listed here https://www.sierrachart.com/UserControlPanel.php?page=SCOrderRoutingServiceTradingAccountAssignmentRequestForm However I am confused on what you will be doing. I trade through a prop shop called FCT, and I already use, and pay for, TT to enter orders via my clearer/prop shop and am unsure whether you will be messing around with my account somehow? You state 'Once your account is set up on TT and it has been assigned to your Sierra Chart account, then you are all set.' Is this just for Amp futures/TT? Can you explain what you will be doing in my specific example as I don't want to mess up anything on the back end. I don't think the corporate clearer will like you connecting my prop shop TT account to your own?! Regards, Ted |
| [2020-03-02 19:42:21] |
I trade through a prop shop called FCT, and I already use, and pay for, TT to enter orders via my clearer/prop shop and am unsure whether you will be messing around with my account somehow? You state 'Once your account is set up on TT and it has been assigned to your Sierra Chart account, then you are all set.' Yes this will work. We will not have access to your account. Only you will. Please complete this form:https://www.sierrachart.com/UserControlPanel.php?page=SCOrderRoutingServiceTradingAccountAssignmentRequestForm I don't think the corporate clearer will like you connecting my prop shop TT account to your own?! This is not what is happening. The account is just made available to the FIX order routing connection we use to TT.If there are still concerns, then do open a $200 account with AMP: Easy Solution to CME Funded Trading Account Requirement Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-03-02 19:44:21
