Date/Time: Thu, 02 May 2024 03:16:43 +0000
Demo OEC account
View Count: 1264
[2014-01-08 09:13:51] |
User78347 - Posts: 17 |
What diffrence does it make if i log to the Demo OEC (with my demo password)+ the sierra with prop.openecry.9200 (with my live password) is it possible? I try to log to the Demo OEC+ sim.openecry.9200 and it didn't work. It did work Demo OEC+prop.openecry.9200. The main issue is: if i log to the Demo OEC (with my demo password)+ the sierra with prop.openecry.9200 (with my live password) and put orders to buy/sell does the orders refers to the Demo account? |
[2014-01-08 09:15:46] |
If you are connecting to prod.openecry.com:9200, this is a live connection. The orders will not be simulated. They are going to be live orders unless you have enabled Trade >>Trade Simulation Mode On within Sierra Chart.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-01-08 09:16:32
[2014-01-08 13:49:06] |
Attached picture of the setting, according to your answer, is it ok?
20140108_153924.jpg / V - Attached On 2014-01-08 13:46:47 UTC - Size: 2.48 MB - 415 views |
[2014-01-08 17:46:52] |
Yes. With that option enabled your orders will be simulated.
