Date/Time: Sun, 19 May 2024 08:48:18 +0000
[User Discussion] - Need AVERAGE line for Number of Trades study
View Count: 515
[2020-02-29 15:52:20] |
User685606 - Posts: 29 |
I have a chart that I am using just for the Number of Trades study. I have the chart settings "Graph Draw Type" set to BLANK because I don't need the chart, I just need the Number of Trades. Is there a way to get the Number of Trades volume per X time period WITHOUT having it attached to a chart since I don't need the chart at all? And, is there a way to add an AVERAGE line of a different color with a number output to the Number of Trades so I can see the average vs guesstimating what it might be?
Attachment Deleted. Sierra vol per x.png / V - Attached On 2020-02-29 15:42:55 UTC - Size: 9.54 KB - 196 views |
[2020-02-29 16:20:38] |
Ackin - Posts: 1865 |
Any moving average from the default Sierra studies with a change "Based On" in the study settings (you can give another study as the source) For example Moving Average - Simple study Output Drawstyle (values, graphics), Width and Colors you can change in the tabs Subgraphs in the study settings Is there a way to get the Number of Trades volume per X time period WITHOUT having it attached to a chart since
Look at:Moving Average - Time Period study Moving Average - Time Period In some situations, however, this will not be accurate. Of course, the study fails to split the bar in half. For a more accurate result I would recommend doing a calculation on a time chart (in the Chart Settings >> Bar Period Type... Days-Mins-Secs Per Bar) and transmit the result via Price Overlay Study to your chart Date Time Of Last Edit: 2020-02-29 16:31:33
