Date/Time: Mon, 29 Apr 2024 06:55:48 +0000
[Locked] - sierra chart ERROR MESSAGE INITIALIZATION ERROR:
View Count: 1768
[2014-01-08 01:45:17] |
DAVID SUDDUTH JR - Posts: 33 |
I am getting an INITIALIZATION ERROR: Error creating the alert manager object. If you need more help, contact Sierra Chart Support for assistance. I downloaded new version and I got this message. I re downloaded previous version and I still get this message. Once message ERROR comes up the software stops and will not upload. DAVID |
[2014-01-08 02:15:22] |
This is unusual. Please try restarting your computer.
[2014-01-08 02:25:07] |
SIERRA- Yes very weird but restarting computer did not work. Please call me so we can do remote access so you can see for your self. thanks |
[2014-01-08 02:45:16] |
We see what potentially can cause this. Go to the folder that Sierra Chart is installed to on your system and rename this file: SCAlerts.json To this name: SCAlerts.json.noread After this attach this file: SCAlerts.json.noread to this thread. You can set it to be private. So only we see it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-01-08 02:52:41] |
I tried it but it did not work....... easier to call me and do remote..... i will pay
Attachment Deleted. Attachment Deleted. SCAlerts.json.noread - Attached On 2014-01-08 02:51:44 UTC - Size: 389 B - 445 views |
[2014-01-08 02:57:01] |
After re naming folder, I tried to log in and it now works! What caused this?
[2014-01-08 02:58:37] |
Renaming what folder?
[2014-01-08 03:03:05] |
I did what you said......... Go to the folder that Sierra Chart is installed to on your system and rename this file: SCAlerts.json To this name: SCAlerts.json.noread after doing this, software booted up. |
[2021-05-24 08:49:28] |
pMathisen - Posts: 9 |
I have the same problem. But I dont even got the SCAlerts.json in my sierra chart folder.
[2021-05-24 09:00:13] |
This thread is very old. We are locking it. Start a new thread and tell us precisely what the problem is.
