Date/Time: Sun, 28 Apr 2024 05:42:25 +0000
BTCUSD-BTCE: Date range start 2013-08-28
View Count: 1029
[2014-01-07 22:29:19] |
User15344 - Posts: 1 |
I can not get the data for the charts before 2013-08-28. Chart/Chart Setting > Date Range in File - not to do (download new version, delete, etc), always start with 2013-08-28 How to fix? A month ago, was available from 2011-08-21 |
[2014-01-09 10:33:13] |
If you use the symbol from MTGox you will get more history. You can find it listed in File >> Find Symbol.
