Date/Time: Mon, 29 Apr 2024 12:16:16 +0000
[User Discussion] - auto study placing one trade
View Count: 1300
[2014-01-07 21:42:46] |
fhvtrading2 - Posts: 11 |
Hi, I would like to implement a study that will place one auto order when turned on. I am not sure what the best approach would be to make it stop repeating new trades when the first one is finished so I can activate it and leave it alone. Basically I am looking for a simple way to disable a study after x number of trades. Hope someone has some pointers. Kind regards, Ferry |
[2014-01-08 00:41:02] |
Sawtooth - Posts: 3982 |
You can do this with the Spreadsheet System for Trading study. You could reference cell J52 within a formula in cell J28. |
[2014-01-08 02:22:49] |
I am looking for acsil based solution. Can it be done with ACS buttons?
[2014-01-08 16:51:51] |
For help with the Advanced Custom Study ToolBar buttons, refer to this page: https://www.sierrachart.com/index.php?l=doc/doc_MouseAndMenuInteractionFromACStudy.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-01-09 02:12:03] |
I have the following code snippet where I try to enable a study based on pushing the ACS button. But it doesn't seem to work. Can this be done? Thanks in advance for any pointers. SCInputRef Enabled = sc.Input[0]; // wait for an event if (sc.MenuEventID != 0) { if (sc.MenuEventID == SC_ACS_TOOL1) { Enabled.SetYesNo(1); } } else { Enabled.SetYesNo(0); } if (!Enabled.GetYesNo()) return; /// the rest of my study |
[2014-01-10 02:05:22] |
Figured it out how to do this. Its a nice feature to toggle between strategies. Hope somebody can use it as well. Goodluck. FHV if (sc.MenuEventID != 0) { if (sc.MenuEventID == SC_ACS_TOOL1) { if (sc.MouseEventType == SC_ACS_TOOL_ON) { Enabled.SetYesNo(1); } else if (sc.MouseEventType == SC_ACS_TOOL_OFF) { Enabled.SetYesNo(0); } } } if (!Enabled.GetYesNo()) return; // rest of the study // place an order with brackets when completed //.... // acs button to off sc.SetACSToolEnable(SC_ACS_TOOL1, false); Enabled.SetYesNo(0); Date Time Of Last Edit: 2014-01-10 02:07:41
