Date/Time: Sun, 19 May 2024 04:11:08 +0000
5 Year T-Note DOM
View Count: 500
[2020-02-28 13:24:01] |
User820310 - Posts: 1 |
After I tried different price formats and tick sizes that you can use for US Bonds, the orders overlap or they still have gaps between Buy and Sell Columns. p.s. It didn't change with the rollover |
Attachment Deleted. 2020-02-27 17_18_15-Greenshot.png / V - Attached On 2020-02-28 13:22:39 UTC - Size: 258.63 KB - 264 views |
[2020-02-28 18:11:45] |
Update to the latest release. There were some changes made to resolve this. You can upgrade using these instructions: Software Download: Fast Update You have also been receiving a technical notice about this when starting Sierra Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
