Date/Time: Tue, 28 May 2024 02:37:38 +0000
study/configuration settings transfer
View Count: 507
[2020-02-28 04:51:59] |
User486817 - Posts: 82 |
hello, i have multiple installations of SC running on my machine simultaneously (it's easier for me). how can i transfer all of my study configurations/right click menu/chart settings/global settings etc over to a different installation? is there a configuration file i can drag and drop from C:\SierraChart to C:\SierraChart2 or C:\SierraChart3? if this is possible, please let me know which files to copy and paste. thank you. best regards, |
[2020-02-28 09:53:18] |
Yes this is possible. What files to transfer is explained in help topic 15: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation In particular refer to step 5. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-02-28 09:54:23
