Date/Time: Sun, 19 May 2024 08:28:44 +0000
Custom Study
View Count: 599
[2020-02-28 03:12:54] |
Bubba - Posts: 30 |
Hello I had a programmer suggested to me through the support board. I have recieved files and can't, don't know how it put them into sierra charts. Thanks so Much Mark |
[2020-02-28 07:52:05] |
Ackin - Posts: 1865 |
if it has a .dll extension then move this file to the "Data" folder in your Sierrachart if it has a .cpp extension then you have to "Build an Advanced Custom Study from Source Code" How to Build an Advanced Custom Study from Source Code |
[2020-03-02 03:04:47] |
Follow the instructions here: How to Use an Advanced Custom Study or a Study Collection Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
