Date/Time: Sun, 04 Oct 2026 13:20:32 +0000
Vanishing Global Crosshairs
View Count: 1213
| [2020-02-27 23:12:04] |
| gayer2428 - Posts: 99 |
I have 3 charts (3 timeframes) open in my Chartbook. Global Crosshairs (Global Cursor) is enabled; Synchronize Charts also enabled. Very often the global crosshairs on one of the charts (almost always the shortest timeframe) disappears, but it's still visible and synchronized on the other 2 charts (2 larger timeframes). To get back the crosshairs I have to click the chart (change chart focus) on which the crosshairs/global cursor was missing. How do you fix it? Thanks. |
| [2020-03-02 00:34:31] |
| Sierra_Chart Engineering - Posts: 25048 |
Refer to: Chart Drawing Tools: Global Cursor Not Active on All Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
