Date/Time: Sun, 19 May 2024 05:43:32 +0000
Software Performance
View Count: 578
[2020-02-27 20:20:59] |
User392279 - Posts: 67 |
Hi My laptop equipped i8650u and 16GB ram with 256GB SSD It should be not bad hardwares but I find when load es markets depth on a 1tick chart with other study loaded it responses very laggy. Like drag the chart not smooth. Does upgrade new hardware will help? If so what is more important CPU or GPU? Thanks |
[2020-02-28 03:34:12] |
Have you tried using the OpenGL option? Refer to: Graphics Settings: Use OpenGL for Chart Graphics (Global Settings >> Graphics Settings >> Other) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-02-28 03:35:15
[2020-02-28 08:44:09] |
It did help. But there some issues like not sharp rendering and color seems not accurate.
