Date/Time: Sun, 28 Apr 2024 08:25:35 +0000
No problem connecting till today
View Count: 1106
[2014-01-07 20:04:47] |
sierra - Posts: 22 |
Cant connect at all today. Could you advise? TransAct - Starting server: C:\Users\Kurt\Transact\TransactToSierraBridge.exe | 2014-01-07 15:04:43 TransAct: Connecting to the server 127.0.0.1. Port 1869 | 2014-01-07 15:04:44 Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2014-01-07 15:04:45 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-01-07 15:04:45 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-01-07 15:04:45 TransAct: Disconnected from the server. | 2014-01-07 15:04:45 Will reconnect to the server in 45.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-01-07 15:04:45 File >> Disconnect selected. | 2014-01-07 15:04:48 TransAct: Disconnected from the server. | 2014-01-07 15:04:48 |
[2014-01-07 21:01:45] |
You are experiencing a problem connecting to the TransAct to Sierra Bridge program. Refer to this section here: http://www.sierrachart.com/index.php?l=doc/TransAct.php#BridgeConnectionError Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
