Date/Time: Sun, 05 May 2024 01:26:46 +0000
Display 'Value on High' only for Last bar
View Count: 1492
[2020-02-27 05:23:46] |
HAB-User115006 - Posts: 38 |
I want to display the Momentum at the High of the Last bar After the bar closes I would like that value text to dissappear and then display for the new bar I was wondering if there is a way to do this using 'Value on High' style, which works but also leaves the values on previous bars which clutters up the chart Thanks |
[2020-02-27 09:00:09] |
Have a look at this study: Text Display For Study You can add multiple instances of that to the chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-02-27 09:00:14
[2020-02-27 18:24:04] |
1. Yes I have seen 'Text Display For Study' study but it does not automatically mocve the text to the top of the ;ast bar when a new bar gets added, if that wewr possible then this study would work 2. I was thinking more like a Draw style like 'Value on High Last Bar only' so the value is plotted on top of the last bar, and when a new bar is added old value gets moved and now appears on the new last bar Thanks |
[2020-02-27 18:33:36] |
Ackin - Posts: 1865 |
I have this study. I did it for my customer.... contact link: https://www.sierrachart.com/UserControlPanel.php?page=StudyStore&SCDLLName=zyp_download_free Date Time Of Last Edit: 2020-02-27 19:04:22
Last value2.png / V - Attached On 2020-02-27 19:03:52 UTC - Size: 12.14 KB - 479 views |
