Date/Time: Sun, 19 May 2024 12:35:56 +0000
Send spreasheet to user - formulae not transferred
View Count: 467
[2020-02-26 22:24:18] |
User556932 - Posts: 31 |
Hi, I have 2 instances of SC. one on my laptop which I use for backtesting etc, and one on a VPS which is used for trading. when I send a .cht to my VPS using the Send File to User functionality (which includes a spreadsheet for trading) the spreadsheet arrives, but all the formulae are missing from the cells. can you please advise how to send so the formulae remain embedded in the .scss? Thanks in advance |
[2020-02-27 08:11:31] |
Did you also send the Spreadsheet file itself with the SCSS file extension? You need to send that file as well.
[2020-02-27 09:33:14] |
yes, the spreadsheet arrives with the correct name, but as I said, there are no formulae in Columns (eg K : Buy entry) I belive it is part of the .cht group.... or is it necessary to send the .scss separately? |
[2020-02-27 09:49:58] |
or is it necessary to send the .scss separately? Yes it is necessary to send separately. You will need to delete the default created one from the destination instance, before sending it again.
