Date/Time: Sun, 19 May 2024 12:15:22 +0000
Bracket Orders
View Count: 1168
[2020-02-26 13:50:26] |
cfuture - Posts: 64 |
is it possible to configure sc in order for the bracket orders to move in-sync with the main order when adjusting the main order?
[2020-02-27 09:11:25] |
Yes this is inherently the case and we do not know why there would be a problem. Also refer to this setting: Global Trade Settings Windows: Adjust Attached Orders to Maintain Same Offset on Parent Fill (Global Settings >> General Trade Settings >> General) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-02-27 09:11:35
[2020-02-27 13:54:40] |
after you move the main order, then the bracket orders adjust, but they remain fixed only until then. It would be great to have them move in tandem.
