Date/Time: Sun, 19 May 2024 04:12:06 +0000
Keyboard shortcut 'Non-Attached Limit Order Tick Up/Down' broken
View Count: 567
[2020-02-26 13:25:01] |
samual sprat - Posts: 343 |
Updated to 2056 and when live I try using keyboard shortcuts to move the limit order up and down but it doesn't behave correctly and moves erratically. Went back to 2053 and it works fine again
[2020-02-26 23:52:53] |
There definitively is no problem with this functionality and we will never believe that. It is simply impossible and this has been tested to work properly. The issue is on your side. We also recommend enabling order confirmations to see that the functionality does work properly. Do not turn off confirmations for order modifications. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-02-26 23:53:28
