Date/Time: Sun, 19 May 2024 06:24:59 +0000
[User Discussion] - Need help for alert on degree of slope
View Count: 982
[2020-02-24 18:39:11] |
User351605 - Posts: 76 |
Hello Everyone, I'd need some help to set up an alert on a range of degrees ( for instance 0°-10°) of a slope based on cumulative delta. I assume I should use the study angle but I have no clue how to output the degree of slope. Furthermore I would need to specify the distance in which the degree of slope will be measured. I would appreciate it a lot if someone could help me Thanks! |
[2020-02-25 00:05:08] |
Sawtooth - Posts: 4000 |
The Study Angle study will do what you want. It outputs in degrees, you can set the lookback Length, and you can base it on a subgraph of the cumulative delta study. Study Angle Try this alert formula: =AND(ID1.SG1>0,ID1.SG1<=10) |
[2020-02-26 08:36:23] |
Thank you!
[2020-02-27 09:57:39] |
Unfortunately this alone is not what I need. The values are not right away usable degrees of a tilt. Do you know how to set up an alert for, let's say, the study angle SG increases from -40 to + 20 over the duration of 3 bars? Even better would be a relative increment in percent, instead of abs values ( -40 to +20) Date Time Of Last Edit: 2020-02-27 10:02:24
[2020-02-27 13:37:23] |
It's not clear to me what you need. What is the expected 'relative increment in percent' if it went from -40 to +20 over 3 bars? If you set the study's Length to 3, the current bar will have the slope over 3 bars. Must the slope also cross zero for an alert? |
[2020-02-27 14:56:09] |
Yes you are right with period setting. I'm pretty new to this and sometimes I don't see the most simple solution. The slope doesn't need to alert when crossing zero Thanks! |
