Date/Time: Fri, 03 May 2024 13:31:31 +0000
Will SC being adding the Market Stat for the Russell 2000 Advance/Decline?
View Count: 1117
[2014-01-07 15:54:33] |
Handle - Posts: 36 |
I think you mentioned previously you may add this. Thanks for your consideration.
[2014-01-07 21:07:17] |
This should not be a problem so long as we can programmatically determine the stocks in that index.
[2014-01-08 13:19:09] |
Ok that's great look forward to having that stat. Russell website and or ICE publishes the list.
