Date/Time: Sat, 18 May 2024 19:51:23 +0000
Data
View Count: 465
[2020-02-20 22:39:22] |
User599451 - Posts: 3 |
Hello support, I'd like to ask you for help. I have everything active but I can't see (M) only on YM market. I see [M] on market NQ and ES too. Where is the problém? Thank you very much Martin |
[2020-02-20 23:44:41] |
Ackin - Posts: 1865 |
I had a similar problem before. Try duplicate chart from NQ (Menu >> Chart) and change the symbol to YM (Menu >> Chart >> Chart Settings .. Symbol: ).
[2020-02-21 03:56:07] |
You do not have the exchange active to receive real-time CBOT data. You need to activate that here: https://www.sierrachart.com/UserControlPanel.php?page=ExchangeDataFeedFeatures#Exchanges Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
