Date/Time: Sun, 19 May 2024 01:42:14 +0000
Printing text from a spreadsheet to a chart
View Count: 606
[2020-02-19 23:55:17] |
User48838 - Posts: 112 |
I would like to print "405 minutes" on the chart by accessing a spreadsheet using H36/60 and adding "minutes". Can this be printed on the chart? I tried using Text Display for Study but it seem to be printing a 0 from the cell in the spreadsheet that contains "405 minutes" TY |
[2020-02-20 19:36:12] |
You have the right idea. You just need to change the Spreadsheet cell to be only the value and not include any text. So it should just be =H36/60 and then do not add the word "minutes". Then on the Text Display for Study, add the word " minutes" in the Suffix Text for Display Value. Refer to the following for the Text Display for Study study: Text Display For Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
