Date/Time: Sun, 19 May 2024 04:56:17 +0000
LIMIT if TOUCHED ORDERS DENALI TT
View Count: 693
[2020-02-19 19:28:22] |
User220914 - Posts: 239 |
Looking for a way to get an OFFSET to work on a LIMIT if TOUCHED ORDER and also being able set up my dom for a 1 click limit of touched order. I can set up the dom for LIMIT and stops and stop limits but not limit if touched Also no way to use a triggered limit unless it is used as a stop order. YES i know i can use the drop down price bar and get a limit if touched but then i have to go find teh order and adjust it. If you look at other services that offer server side execution and charge for it you will see that the next step is to offer order types that sit server side instead of client side in order to ACTUALLY take advantage of the server sending orders FASTER. Do you have a date to implement server side orders or is this something that will be done when you stop using TT? thanks |
[2020-02-20 18:42:45] |
We will add Limit if Touched orders as a Chart DOM order type. And we will be adding server managed market/limit if touched orders as soon as we can. Also we do not plan to stop using TT. We are going to offer direct CME order routing but TT will also be supported and will be needed for other exchanges. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-02-20 18:59:30
[2020-02-20 22:40:06] |
seandunaway - Posts: 214 |
Imagine if we could run some custom ACSIL when mouse clicking on the DOM! Some examples might be: - Consume all contracts on the book at the clicked price level, up to the Qty, fill or kill - Lay out 10 orders of 1 lots at the clicked price level - Place a limit order with a random quantity between a min and max, at the clicked price level We could implement all of the TT style order types and algos https://library.tradingtechnologies.com/trade/tto-order-types-overview.html |
[2020-02-20 23:35:53] |
sounds great and thank you very much
