Date/Time: Sun, 26 May 2024 13:41:29 +0000
DTC prices with Denali question
View Count: 599
[2020-02-19 17:57:02] |
onnb - Posts: 661 |
We have an application that connects to SC with DTC (SC running as a server). Before we were using "Sierra Chart All Services" and things were working fine. Recently we switched to Denali and are seeing ES/NQ price values that have no decimal places. For example, we receive ES prices as 337150 instead of 3371.50. Have you heard of this before? Is it something we need to configure on SC side? or is there some multiplier/divisor we need to apply in our app that is part of the symbol definitions? Hope this makes sense |
[2020-02-19 18:38:07] |
Yes this does make sense when using the Sierra Chart order routing service. This is explained here: DTC Messages and Procedures: Market Data Price Format You will get the DisplayPriceMultiplier from the security definition message which can be set to be automatically sent in the DTC server settings in Sierra Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-02-19 18:38:13
[2020-02-20 19:29:46] |
onnb - Posts: 661 |
You mean "Auto Send Security Definition For New Symbols" ? |
[2020-02-20 19:32:05] |
Yes.
