Date/Time: Sun, 19 May 2024 05:43:10 +0000
VolumeByPrice display error FVH20
View Count: 508
[2020-02-19 05:54:59] |
User71961 - Posts: 144 |
perhaps related to the error that caused the price display error? the VolumeByPrice study for ZFH20 is now wacked. My chart is set to VolumePerBar - 3000 The VolumeByPrice - VisibleBars study is just one large box covering half the screen any ideas? i just updated to version 2054 http://www.sierrachart.com/image.php?Image=1582091519857.png |
[2020-02-19 06:45:37] |
Check the Tick size and the Volume at Price Multiplier in Chart >> Chart Settings and make sure they are correct. We are not observing a problem ourselves.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-02-19 06:45:45
