Date/Time: Sun, 19 May 2024 08:47:29 +0000
Study Summary Window No Longer Sorts by Symbol or Name
View Count: 468
[2020-02-18 20:34:30] |
Tom Wielgus - Posts: 7 |
Hi, I updated to version 2054 64-bit. I am on Service package 3. I am no longer able to sort Study Summary Window results by Symbol or Name. (It will still sort on numeric values). While probing for a solution, I also found that changes I try to make in the Description field of the Symbol Settings Window are not being recognized. The "Use Custom Symbol Settings Values" box is checked. |
[2020-02-18 21:43:46] |
We will test the sorting. Also if a Description is received from the remote data feed for the symbol that description will be used instead. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-02-18 22:32:38] |
Hi, More info - may be of some help: When I click on the Symbol column header in the Study Summary Window, the charts sort by chart number. I have found that the changes I make in the Description field of the Symbol Settings Window are recognized once I completely exit Sierra Chart and later re-open by logging in. |
