Date/Time: Sun, 13 Jul 2025 07:08:49 +0000
[User Discussion] - horizontal study bars
View Count: 633
[2020-02-17 21:57:45]
User12089 - Posts: 365
is there anyway to create a custom study which draws horizontal (rather than vertical) bars, moreover along the Price Axis (essentially like what e.g. a Volume Profile Histogram looks like when fixed to the right side of a chart)
Can use ACSIL etc - but whats the way ?
the data for the study will come from outside SC, so no need to synchronize anything with the internal study callbacks of SC - the study will simply visualize extrnal data like a "vertical histogram" fixed to the ride side of the chart / the price axis
[2020-02-17 22:10:54]
Ackin - Posts: 1865
simple ... use sc.UseTool()
Using Drawing Tools From an Advanced Custom Study: Using Tools with sc.UseTool()
imagepf.png / V - Attached On 2020-02-17 22:10:46 UTC - Size: 68.22 KB - 252 views
[2020-02-17 22:12:56]
thanks, and any way to achieve the same by using the SC spreadsheet study ?
[2020-02-17 22:17:02]
Ackin - Posts: 1865
How many values (how many horizontal bars) do you need?
[2020-02-17 22:49:30]
well, in general, one per price level, but at the same time there is no need for infinite number of levels away from the current/best price
[2020-02-17 23:12:49]
Ackin - Posts: 1865
It would be possible to create a universal study drawing profile, for example for 20 price levels ... it would be the input of two user-defined arrays (two inputs IDx.SGx), first being price-lvl, the second value as the bar size. .. using Spreadsheet filling the first and second supgraph of their value.
Probably there would be a few situations where the conditions would have to deal with what happens when the same price level is shown, but that would be solved by the study settings form.
[2020-02-17 23:19:41]
by excel spreadsheet i meant the standard SC Excel Spreadsheet Study and whether there was a way to use its params / formulas to achieve the above stated objective
otherwise for a custom ACSIL study, yes the input can b eexcel, csv file, messages etc whatever
