Date/Time: Sun, 19 May 2024 12:15:54 +0000
HL avg line on DOM
View Count: 5934
[2020-02-17 11:58:05] |
User449811 - Posts: 8 |
Is it possible to load the HL avg line (half-back) on the DOM. In the screenshot linked underneath, it's added manually with the horizontal line tool. Can it be set as a study on the DOM next to the volume profile? http://www.sierrachart.com/image.php?Image=1581940547506.png |
SC-DOM chart.PNG / V - Attached On 2020-02-17 11:51:59 UTC - Size: 34.55 KB - 215 views Attachment Deleted. |
[2020-02-17 13:37:35] |
User48838 - Posts: 112 |
If you add the Daily OHCL study to your chart, you can then Overlay it onto a DOM
[2020-02-18 21:46:45] |
You can add the Daily OHLC study to a Trading DOM which supports the midpoint: Daily OHLC To add studies to a Trading DOM: Chart Trading and the Chart DOM: Adding Studies on a Trade DOM Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
