Date/Time: Mon, 29 Apr 2024 15:32:18 +0000
Trade DOM orders executing between tick sizes
View Count: 618
[2020-02-14 18:48:18] |
User996502 - Posts: 28 |
Orders are being executed at prices in between the ticks(screenshot). How do I adjust so that they properly align with the tick sizes?
Capture.PNG / V - Attached On 2020-02-14 18:48:00 UTC - Size: 42.93 KB - 214 views |
[2020-02-14 23:04:24] |
That does not make sense. Refer to: Trading Information Windows: How Average Price for Positions Is Calculated and Used Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-02-17 18:13:25] |
What exactly am I changing on here? The trade activity log shows correct entry and exit price, the dom doesn't. |
Trade activity log.PNG / V - Attached On 2020-02-17 18:13:02 UTC - Size: 59.06 KB - 189 views |
[2020-02-17 18:20:44] |
There is not a problem here. What you are seeing is the average price of order fills.
[2020-02-17 18:23:25] |
Isn't there an option to round this to the tick size it gets filled at instead of keeping it in between?
[2020-02-17 20:53:05] |
No there is not and that would never be added.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-02-17 20:53:13
