Date/Time: Sun, 04 Oct 2026 10:19:03 +0000
Data/Trade Service Settings
View Count: 772
| [2020-02-14 01:56:11] |
| User488622 - Posts: 8 |
I'm using TTfix and have no idea what to use for any of the Data/Trade Service Settings. Should the Price Session Server be TTfix? What about the Order Session Primary Server? What passwords do I use for them? Is the username the login name I use for my Dorman Account? I searched the Support Board for "Order Session Server" and found nothing. Thanks
| [2020-02-14 03:33:38] |
You are not using TT FIX directly. What you need to do is follow the instructions starting at step 9 here: https://www.sierrachart.com/index.php?page=doc/SierraChartOrderRoutingServiceWithData.php#SetupInstructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-02-14 03:34:01
