Date/Time: Sun, 04 Oct 2026 10:19:03 +0000
Spreadsheet study average of zig zag line length
View Count: 1588
[2020-02-13 14:12:39]
grantx - Posts: 244
The zigzag study shows me the length of each swing.
I can see these numbers plotted in the spreadsheet study in the AF column.
I want to get an average of the last 10 swings.
The problem is that there are a lot of zeros before a new swing prints. See attached.
How do I create a formula to put into the K column, which only gives me an average of numbers that are not zero?
I just want a single cell to display the average and not copied down the entire spreadsheet.
image1.png / V - Attached On 2020-02-13 14:12:21 UTC - Size: 3.49 KB - 440 views
[2020-02-14 04:12:21]
Refer to the following to help you with this:
Spreadsheet Example Formulas and Usage: Return Last Two Zig Zag Reversal Values
Also refer to:
https://www.sierrachart.com/index.php?page=doc/SpreadsheetFunctions.html#AVERAGE_IGNOREZEROS_Function
Date Time Of Last Edit: 2020-02-14 04:49:33
