Date/Time: Tue, 14 May 2024 12:50:31 +0000
Candles In Front Of Lines
View Count: 931
[2020-02-12 23:52:19] |
User9415867 - Posts: 38 |
Is there a setting so the candles are in front of the drawn trend lines or drawing objects as opposed to behind them?
[2020-02-13 17:49:55] |
Refer to the following Chart Setting and the three after it: Chart Settings: Draw Non-Highlight Chart Drawings Underneath Main Graph and Studies (Chart >> Chart Settings >> Chart Drawings menu) (Draw Non-Highlight Chart Drawings Underneath Main Graph and Studies) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-02-13 17:50:39
