Date/Time: Sun, 28 Apr 2024 15:47:45 +0000
[Programming Help] - Unknown "stopLoss" text
View Count: 451
[2020-02-12 20:32:20] |
User917679 - Posts: 76 |
I'm trying to identify where this yellow text came from, and its specific function; I checked my chart studies, but I don't see anything corresponding to it... I did notice it pop up straight after an order filled whilst in sim mode though.. |
Attachment Deleted. sltext.png / V - Attached On 2020-02-12 20:31:19 UTC - Size: 25.64 KB - 184 views |
[2020-02-12 22:38:57] |
There is no Sierra Chart study which would add that. It must have come from a custom study or was manually added. Most likely it is from a chart drawing. So you will see it in Tools >> Manage Chart Drawings Window. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-02-12 23:39:00] |
I checked drawing settings and I still don't see anything corresponding to it(I have a few extended lines drawn on my chart; that's all that shows up)... ..The numerical portion of this yellow text is constantly changing its value, so its definitely linked in some way to receive input |
[2020-02-14 16:01:28] |
bradh - Posts: 854 |
Try hiding one study at a time until it disappears, then you should find out if it is coming from a study and which one.
[2020-02-14 16:02:44] |
Therefore, this must be coming from a custom study. As has been said hide the studies in Analysis >> Studies to see which one it is.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-02-14 16:02:59
[2020-02-14 21:58:20] |
Alright, this finally worked! It was one of the studies as suspected |
