Date/Time: Sun, 28 Apr 2024 19:33:03 +0000
Position older than a number of bars in ACSIL
View Count: 551
[2020-02-10 18:36:13] |
sugart - Posts: 25 |
How do we incorporate in ACSIL code the condition to sell or cover a position if it is older than a number of bars? Is there any relevant ACSIL example? Thanks. |
[2020-02-11 05:59:14] |
Basically you would remember in a persistent variable the bar index where the Trade Position was entered: sc.GetPersistentInt() Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-02-11 06:11:37] |
What about my second query? Do you have any relevant examples in your documentation?
[2020-02-11 19:38:48] |
So what you would do is calculate the difference between the latest bar index, which can be determined with sc.ArraySize -1, and the saved bar index and use one of these functions once the difference exceeds a specified amount: Automated Trading From an Advanced Custom Study: Cancel Orders and Flatten Position Functions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-02-11 19:38:57
