Date/Time: Wed, 08 May 2024 01:25:57 +0000
TPO / Volume Profile doesn't show full session
View Count: 642
[2020-02-10 11:01:31] |
User351605 - Posts: 76 |
Hello, I have two TPO / Volume Profile charts and one of them doesn't show the full session, and I have no idea what might be wrong with it. I took over the same settings from one chart to the other (except graphic settings) Wold you be so kind and tell me why this happens? I've attached the chartbook thank you! Date Time Of Last Edit: 2020-02-10 11:02:20
Private File |
[2020-02-10 18:04:33] |
You do not have the exact same settings between the TPO studies. In particular the settings for New Period at Day Session Start when Using Evening Session and Exclude Evening Session Profiles Except for Last Day are set differently, which will cause what you are seeing. Refer to the documentation for these settings starting here: Time Price Opportunity (TPO) Profile Charts: New Period at Day Session Start When Using Evening Session (1 Day Period Only) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
